Discuss din rail mounted bell transformer - earth? in the DIY Electrical Advice area at ElectriciansForums.net
hi
i've bought a hager st303 din rail mounted door bell transformer and a 2 module wylex ESE2 enclosure for it to fit in. i was going to run this off a 3A FCU.
i can't see any earth connection on the transformer from the photo - it haasn't arrived yet - and there's nothing to earth in the plastic enclosure. what should i do with the earth from the incoming power cable?
any advice appreciated, thanks in advance.
Make sure the CPC in the supply cable is properly earthed at it's origin, then inside the enclosure, expose it and sleeve it so no copper is visible and leave it unconnected. You may require it in the future.
ok great, thanks for the advice!
Reply to din rail mounted bell transformer - earth? in the DIY Electrical Advice area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
I hoped someone might advise please: I'm replacing my ancient ( probably 40+ yrs old ) door bell transformer with a British General unit mounted...
