Discuss Do you HAVE to fix Henley blocks to a wall? in the UK Electrical Forum area at ElectriciansForums.net
all connections of cables should be secured . this is to prevent strain on the terminations.
A clue might be if it has screw holes inside the block.
If the block had internal clamps to hold the cables secure as plugs and lampholders do, then it could be argued that fixing is not required, but they don't have them.
As per Telx, there won't be a specific reg for Henleys or other makes that achieve the same result, just a general rule.
A wall as oppose to? You thinking post mount?
No I mean someone I work with has just joined the tails and added a db in. But he hasn’t fixed the Henley blocks in the meter cupboard. There just hanging inside the box. I always fix them to the wood and make it neat. I was wondering if there’s a valuable reason why this is not acceptable.
Not securing them is at the very least, dog rough work imo.
Is there a regulation as such for a Henley block to be fixed to the wall?
Connections should not be under undue strain, so the service connection block should be properly secured and the connected cables suitably restrained.
You should take account of the manufacturers instructions, which will undoubtedly tell you to fix the block using the screw holes.
Screwing the Henley in place also makes terminating the Cables much easier imo.
imo it’s rough to have it just flapping about in the wind.
but again it’s one of those things you will find quite often
Reply to Do you HAVE to fix Henley blocks to a wall? in the UK Electrical Forum area at ElectriciansForums.net
In the UK, It is said that the neutral wire is connected to ground/earth wire along the way back to the substation. Ive inherited a setup where...
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
Hi all, The service cable is on the outside of my wall in the porch. What’s the best way to cover it with complying with current regulations...
