Discuss Do you need to PAT test / test fixed appliances in the UK Electrical Forum area at ElectriciansForums.net
Been asked this question today by one of our engineers , do you need to pat test / test fixed appliances / equipment ( hand dryers , heaters etc )
My opinion Yes he thinks no
Something we don’t really do but know we really should and keep records of these tests
I suppose it depends what you mean by "need". It's not the same as "should".
i
Is it a requirement
There is no legal requirement to PA Test anything but the law requires you to abide by the following
• Health and Safety at Work Act 1974
• Electricity at Work Regulations 1989
• The Provision and Use of Work Equipment Regs 1998
• The Management of Health and Safety at Work Regs 1999
The above are legal requirements and the easiest way to comply is to PA Test.
I agree totally
In terms of In service inspection and testing of electrical equipment if there is a requirement in for equipment to be tested (such as when there is no planned preventative maintenance regime in place) then all electrical equipment should be tested at intervals this includes items of fixed or stationary type.
If this were not the case then your EICR of the fixed wiring would omit these and the ISITEE would omit these and they are subject to wear and tear just as anything else so need to be covered somehow.
I tend to take the view that fixed equipment eg via switched fused spur etc. is part of the fixed electrical installation and is tested as p[art of a EICR. Portable appliances done periodically based upon a risk assessment eg plugged in appliances such as computers ,fridges would be of a less risk than say drills in the workshop or the kettle toaster in the staff rest room.
Other than the xed installation, which is considered to be the installation from the meter point to the socket-outlet, or fuse connection unit, all electrical equipment in an installation, whether permanently connected or connected by a plug and socket-outlet,
Code of Practice for in-service inspection and testing of electrical equipment © The Institution of Engineering and Technology
fixed wire testing only covers as far as sockets , fused spurs , isolator
Rest should be covered by in service inspection and testing of electrical code of practise
Maybe I'm missing something here but please enlighten me as how you practically would do this on sat a fixed heater fed via switched fused spur. All the PAT testers that I know of you have to plug the item into.
Really,so what do you do with hand dryers ,a heater in a w.c on a switched fused spur I'm learning here by the way I can't see this paying well especially for the companies that charge very little per item.
Reply to Do you need to PAT test / test fixed appliances in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Not sure if asking about rates is allowed, but I'm wondering what people's thoughts are on chargeable rates for PAT testing. Baring in...
Hi guys, first of all, really sorry if it's a daft question but I'm having a bit of brain fart. Recently I received some calls (for the first...
Hi All, My colleague and I are currently doing PAT/ISITEE Testing, and we've hit a snag with a bit of equipment - we've got 19" Racks for our...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
