Discuss Domestic installation advice in the UK Electrical Forum area at ElectriciansForums.net
FBA1B49B-2CB6-4EA4-A9BE-5B232A320243.jpeg Hi everyone. I’ve been asked to quote for a repossessed property that needs a consumer unit change. The incoming supply configuration is as shown in the image. As the tails come straight of the suppliers meter what is the correct way to approach changing the tails. Do I need to contact the supplier? Thanks
Depends who the energy supplier or dno is for this property. Some suppliers will do install an isolator free.or quite cheaply. Where as dnos vary quite a bit
Western power distributiom charge 75 inc vat to pull a fuse. And wait 1 hour whilst you fit an isolator yourself. Otherwise its another 75 to put fuse in. I always have isolator and new tails on wall ready to go.
SSE allow you if in a scheme to pull the fuse on single phase domestic properties. In anycase if its old and especially if a metal cutout leave well alone. Easily brake or arc. The dno wont pull a fuse out a metal cut out around here due to risks.
If its a nice new modern henley cutout then i gather the seal fairies like to visit these.
exend the tails if required.
considering their is a tele switch his it a flat a house or a barn.
It’s a rather large old house. Been vacant for 6-8 years. Was Eon supply but the tenant ran a high amount of debt before leaving. The new owners are switching supply to Bulb. Can the tele switch be removed in this instance? Maybe the correct approach is to ask the new owners if they have a dual tariff arrangement. Thank you
The new owners must have the new isolator installed before any work is carried out , considering you are qouting for the job .
i would not give to much infomation before you get the job ,if you know what i mean.
I assume the off peak loads controlled by the teleswitch are now gone, I see no connection to the switched output terminals. Might be worth changing to a normal rate supply at the same time if this is the case.
Reply to Domestic installation advice in the UK Electrical Forum area at ElectriciansForums.net
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
We had a new supply installed this week. DNO installed new cut out and fuse externally. Meter operator sent his engineer to move the meter in the...
DNO ripped out antique main incomer/breaker .The guy hated us and himself and everyone else by the end of the job ! . Client going to contact...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
