Discuss Double Sock, One Switch Not Cutting Power Reliably in the UK Electrical Forum area at ElectriciansForums.net
Hello. Had an issue a few months ago with a double electrical socket. One of the switches was stiff and sticking most of the time. I contacted a local electrician to put a new faceplate on which he did. Problem is, ever since then, the righthand switch is temperamental. It clicks on and off normally now but i have noticed that on a few occassions when switched to the off position, things plugged into that socket (an extension cord right now, not overloaded and good quality build) will still remain lit up. I've tried turning my computer on when it is in that state thinking that there might still be a bit of held charge in the extension lead that is tricking me and powering the leds, but the pc turned on and ran as normal so it must have been getting full power. This has happened a handful of times. I'd say 80% of the time it turns off things as it should. It always turns power on with no problems. Oddly, the switch on the old faceplate which stuck was also the righthand switch. Probably just a coincidence. I saw a orange flash once when turning it off, was a milisecond and very small, could have just imagined it but i don't think I did.
Of course I intend to get another electrician to look at it. One is coming out tomorrow actually and I will relay all this info to him. I just thought i'd ask for some insight so i know what type of service fee i'm looking at and if its a quick fix.
I have noticed these sorts of problems before when the wall the accessory is on is not flat such that when the faceplate screws are tightened the faceplate is distorted or bent slightly. In minor cases just loosening the screws slightly can cure it though if that means the accessory can move around that is not a good idea. In more extreme cases I have had success with setting a 10mm spacer plate in the wall over the box with constuction adhesive to provide a flat surface for the accessory to mate to.
Sounds like a cheap replacement accessory to me, possibly affected by poor fixing as said above. Something about buy cheap buy twice?
Reply to Double Sock, One Switch Not Cutting Power Reliably in the UK Electrical Forum area at ElectriciansForums.net
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
Hello. we have had a few powercuts over past few months and am in middle of one at the moment where power has gone off a few times while DNO are...
4K
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
Plasterer has been in this week and after leaving today, he left the light on in the room. I went to the room to turn the light off and saw the...
4K
