R
revolt3k
Whats the requirements for downlights in regads to fire-hoods. is there a page in regs about them?
If they are 3W LED GU-10's do you need to have fire rated fittings or hoods?
I know that noramally mains voltage need to be fire fittings now or have hoods but i was wondering about these new LED lamps. Also do 12V fittings require them.
hi mate its not the type of fitting or lamp that matters if you cut a hole in a ceiling you need something to stop the spread of fire, ie fitting or hood, i use flame guard fittings as hoods tend to fall over.
I see, Thanks Mark
so basically all fittings need to be fire rated now.
what is the required fire rating of the ceiling in question?
any fitting you put in a ceiling that needs to be fire rated must be of the correct type regardless of the lamp used ( its not fire from your lights you see, its fire spreading through a building through the holes you have just created)
so if no rating required then no hoods required
lister can you tell me who would specify about the fire rating of a ceiling is there a doc for this thanks mark
domestic or commercial?
i dont think that there is one doc that covers this subject as its to vast, all depends on type of building, its intended use and what its made of, usually archetect or building inspector (if there involved) will spec or advise, if commercial fire officer/owner usualy.
What about a faulse ceiling below another ceiling above it?
Maybe a bathroom thats had a ceiling lowered, so there is 2 ceilings in all one being where the lights are installed and another 12" above that has noting installed.
Its, belt and braces lads and lasses, we always use fire hoods regardless of extra cost, you cannot be to safe these days.
Indeed, as the cost of these types of fittings are fairly reasonable now so there is no point in not.
With regards to a ceiling above a ceiling then i dont see any reason too, especially if its on the top floor.
Generally, fire rated fittings are required between floors of a dwelling, and not on the top level with loft above.
SPOT ON
personally i try to avoid fire hoods and either not bother or if required use a rated fitting, hoods seem to over heat the lamps especially 50w gu10's and they seem to blow much quicker.
