Discuss Dual heating in the Central Heating Systems area at ElectriciansForums.net
Hi all, got a heating system to connect up soon with oil burner and back boiler. Have recently disconnected the heating system as hot press is being moved. Not your usual set up, the oil burner is controlled via a apt time switch that also outputs to a single pole switch that can turn on a hot water motorised valve.
The back boiler pump has a switched fuse spur taken from ring circuit with a cylinder stat in circuit.
As house is being partly rewired thought I'd run a separate supply for heating, then from new supply in hot-press feed the apt timeclock that turns oil burner on and keep the single pole switch that operates the motorised valve, except I will add a cylinder stat to control the temperature of hot water.
Then the pump for back boiler will have a switched fuse connecting with the stat in parallel, think it goes on return from back boiler to bring pump on automatically incase switch isn't turned on.
Hope this makes sense, just looking confirmation that it is ok to connect like I have described. Not sure of best way to connect a dual heating supply, if anyone knows of a better way of doing it please let me know thanks.
Reply to Dual heating in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
1 - Major supply fault, details unknown. By time I get there DNO already put in genny and are digging up road. 2 - Reason for call, heating not...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
