Discuss dual tarriff consumer unit query in the UK Electrical Forum area at ElectriciansForums.net
W
woodsta
Hi all just a quick one. I am trying to get hold of a 17th edition dual tariff cu, is there such a thing rather than two boards?. I can only find them with two main switches and don't really want the expense of rcbos. can I just change the main switches to rcds?. I know there are many ways but what is the best way/Least expense? Thanks
Buy a split load dual tariff unit (Crabtree Starbreaker do them) and you can probably then change the 2nd supply switch for an RCD if needed. To have each supply on it own overall RCD is not splitting the circuits to prevent inconvenience.
Reply to dual tarriff consumer unit query in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
5K
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
