Discuss Earth connections into new controller board in the DIY Electrical Advice area at ElectriciansForums.net
Hi All,
I have 3 separate Earth wires connected into an existing controller board. These 3 wires all have ring terminals and were hooked to a single brass earth bolt connector on the board. Now, As I'm replacing this board, I realised the new replacement board only has one Earth screw terminal.
What are my options rather than striping the 3 ring terminals and connecting all into this 1 terminal?
Hello, long time reader of this forum but never posted before.Just a quick thought that on the link it says that the connectors are for solid core conductors and the cores in the picture seems stranded. I have never used wago type connectors personally so not sure how they are with stranded cores.
Thanks for the heads up! will look at the wago for stranded cable. Cheers
the wago push fit suit 7 strand cable, but for fine stranded you need the 221 lever type.
Reply to Earth connections into new controller board in the DIY Electrical Advice area at ElectriciansForums.net
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
