there's a thread from yesterday where an EDF "engineer" waved a volt stick next to a water pipe and said it was live because his volt stick lit up.
your thoughts please got called to the in laws resturant fault was sqrews on light switch were live ok so i tested and true enough 230v on sqrews the light switch was a combined mem emergency one way and a 1 way switch changed switch but still happening when the switch is off its ok when switch is on theres 230v on sqrews so up in the gods ie high ceiling with no access at moment is 3 twin light fitting plus 2 running men lights now one of the fittings ballast has burnt out with only one lamp working in the fitting now my guess is am i getting a fault through this ballast and why hasnt it taken out the mcb and yes i have earth continuity back at db once the scaffold is returned to site i can get up to the fittings to find out exactly what is the problem
Jeez, has someone stolen your comma and full-stop keys?? Ha ha, sorry - couldn't resist. Daz
