Discuss Earth Rod Connection in the UK Electrical Forum area at ElectriciansForums.net
Pip
Is this an acceptable connection to an earth rod?
And is the water bond really necessary? (New duel RCD board recently fitted)
Hi - that rod looks like it’s seriously rusted so I would not have used it myself. I doubt the clamp has made good connection through that rust, so for me it’s not ok.
Bonding to water may not be required if the incoming main is plastic and there are tests to confirm.
Yes my thoughts exactly, A new board was fitted in April, and the earth/bonding cables upgraded, this is how it was done.
I've reconfigured some circuits in the property and have replaced this connection with a larger clamp, and have a Ze reading of 190 ohm. (Previously fluctuating to any number you want) And have brought the Zs readings down from 213 to 63.7
Will discuss with the client replacing for a new rod.
Incoming main is plastic, and I know they renewed the gas pipe only a year ago also.
Rod is too close to the building. try a new rod ( screwed togehter rods down to about 12 ft. surround rod with a bag of cat litter.
rods are never copper. steel with a few microns of copper coating. tapes may be copper, like lightning conductors. that's why the pikeys nick 'em.
Reply to Earth Rod Connection in the UK Electrical Forum area at ElectriciansForums.net
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi. The question is..... can saturated ground affect earth resistivity testing equipment? Some days there's an unacceptable earth reading, another...
