Discuss Earthing of light switch plates in the UK Electrical Forum area at ElectriciansForums.net
Gary C
Excuse me if this is a dumb question but if i have earthed metal back boxes for all my light switches and i replace the front plates for all metal ones, do i need to also earth these or are they naturally earthed through the metal screws that hold them to the back box?
Some say if one of the lugs are fixed then there is no need, but I wo9uld always use a lead to the back box if a terminal is provided.
What Pete said ,for the sake of a few minutes just put a lead from the box
i do it the other way. divert the cpc's from box to faceplate, then if i can be arsed, fly lead to box.
catch22 though is if you omit the lead to the back box, which was previously earthed, are you leaving it less safe than before? :eek:
I must admit I used to take a lead to the box but one day I thought "Why am I doing this?" After all the socket will never be energised unless the back box is inaccessible, will it?:D
not untill percy painter ot wally wallpaperer lifts them of for decorating purposes.
I find most decorators just paint round them in situ, and badly at that! Really winds me up it does. I would hope that Wally W would loosen any plates though.
I was round at a job the other month and there were some plasterers skimming a couple of rooms, including 2 walls which they were also undercoating. The face-plates were all well off the wall and one of the ones where they were undercoating had loads of wet plaster squeezed into it. I knew the power was still on as I had just been looking at the CU so I asked them if they always did it like that "Yeah been doing it years mate never had a problem"............
Reply to Earthing of light switch plates in the UK Electrical Forum area at ElectriciansForums.net
This is confusing, I've ordered a few bits of this stuff, some switch modules and front plates and in the bumf on the website it says:- Click...
I am wiring up a new kitchen and conservatory. I'm not sure why I checked continuity between line and the metal back box of the light switch, but...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
