W
Woodworker
Hi, I am replacing a “fizzing” start /stop switch on a metal framed woodworking machine , with an NVR switch with emergency stop. The machine itself is mounted on nylon castors which presumably insulate the machine electrically from ground. My question is therefore, where do I attach the earth wire - to the frame or elsewhere? The machine has a 1hp electric motor. Thanks!
