Discuss EIC price? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello,
Was just wondering how much shall I charge for EIC. Double rcd board 18 circuits. Some other sparky did 1st fix and 70% of 2nd fix then he disappeared.
Also there is some remedial works to be done:
Gas bonding, fussd switch to be installed.
How much shall I charge for all above?
Many thanks.
Hello,
Many thanks.
So you are happy to stick your name on a cert when you haven't seen the full install?
You are a brave person to take responsibility for someone else's work.
Hello,
Many thanks.
Unless you had eyes on and had experience of the actuall work involves , I don't see how you can issue an EIC, an EICR might be the best way forward, as you have no idea of how the work was done, and to what standard t's a no win situation, your neck could be on the line Mate
Thank you for your replies,
I thought that there are 3 fields on nic eic certificate (design, construction and testing) but unfortunately is only one signature. So I might just refuse to do EIC.
Well it's no good even considering an EIC Mate as you have no knowledge of how the installation was or has been constructed, end of.
EICR is the way forward on this job, if its your gran then the price is a cup of tea and a biscuit.
if it is anyone else, the price is what you would normally charge on your hourly rate +20% to 30% for the hassle of dealing with someone else's fcuk ups.
Yes but would that satisfy building control..
Not your problem at all, but get the customer to ask them. Unfortunately BC will often allow an EICR for a process known as regularisation, which is sort of notification after the fact.
An EICR keeps your arse out of the sling, make sure you describe the extent and limitations explicitly. ?
Fit the consumer unit and issue an EIC stating alteration to an existing installation, state the work carried out, installation of consumer unit. This limits the work to what you have done the rest of the installation is down to someone else. Just make your intentions clear.
Nice and shiny consumer unit fitted already. Family lives there for almost year I believe. I did mainly wall lights, Garden lights and couple of pendants.
Use a 3 part EIC and put yourself down for testing only and in the description just put testing of all circuits for construction and design put by others, that should cover you.
You can charge per circuit for the testing but don't do it cheap.
You can download a 3 part cert on this site.
You cannot do that.
BS7671 is very, very clear that inspection and testing takes place during erection and on completion. He was not there during erection to witness how things were installed. Therefore he cannot sign for Inspection and Testing on an Electrical Installation Certificate other than for works which he personally did or witnessed.
Sounds like they need the EIC to get it signed off by building control? If you sign off a EIC for work that you have knowingly not been witness to from design through to completion, then you could be, in a court of law, technically committing fraud. Personally I'd take the advice of the good folk and issue a EIC for your own works and offer to do a EICR for the works outside this.
Reply to EIC price? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Hi all, Been asked to quote an EICR on a fairly large installation. Approx. 400 circuits that are a mixture of single and 3 phase. This is across...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Apologies if this is in the wrong section - appreciate it's more of an educational question. That said I have 2391 - but the classroom environment...
Hello, I went to my local takeaway to do some work and the landlord complained the cost of electrics is really high, of course I've heard this a...
