O
Octopus
I've fitted a metal BG board today ................ and it came with the type of CU blank that can be easily removed ................ is this a C3?
Madness.
Madness.
Discuss EICR audits _________ in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Madness.
Madness.
Cheap crap mate. Does not comply imho.
I fitted a schneider 3 phase board in the summer, aparantly they dont even do a din rail type fitted blank only the clip in ones aswell.... I didnt like that on a 3 phase board...
The wilex one i fitted today came with clip in ones aswell but i ordered the din mounted ones to go with it...
says who?
Surely no manufacturer would sell non compliant equipment .....
Got to agree with that comment.says who?
Madness.
says who?
Would you install a CU with a clip on cover?
Are the blanks removable without a tool ?
The problem is easily solved by ordering a lock to fit the DB door if so.
Yes you can really remove any clip in ones if youve got good nails
do those boards not have the switches to turn of the the individual mcb connections ?I fitted a schneider 3 phase board in the summer, aparantly they dont even do a din rail type fitted blank only the clip in ones aswell.... I didnt like that on a 3 phase board...
Just because they can be turned off internally doesn't mean mean that they are turned off. So it must follow that does not give you exception to install blanks that are removable without a tool.do those boards not have the switches to turn of the the individual mcb connections ?
Really ? Last time I installed an acti9 isobar I found it was possible to switch on without a device, just like the old Merlin ones.The new Schneider ones will only switch on with a protective device in place.
Knowing me I probably broke itPretty sure now the Isobar Acti 9 will only switch with a device in place.
Don't you mean the company that you work for has an EICR done periodically if that's how I read it? what hight is this distribution board? if you can stand there and push the blank in then you have direct contact with live parts so fixed blanks would be required they are not expensive.The company I work for periodically gets its EICR'S audited, one thing they pulled us for was plastic blanks in pre Amd3 boards 'easily removed without the use of a tool and readily accessible'
They put this down as a 'code 2'
Can't really fathom this, what about pendants? Which have been overlooked, it's resulted in a return to hundreds of properties fitting MCB blanks.
Any thoughts?
Merlin gerin blanks fit tight in the boards and come in strips of five I would say that these blanks would not be able to be removed without a tool . The only full dinrail blanks I know of are the mem memshield 2 and hager , do any other manufactures make them ?Just because they can be turned off internally doesn't mean mean that they are turned off. So it must follow that does not give you exception to install blanks that are removable without a tool.
Ok ...we have all probably seen some DBs CSUs with holes, no blanks, some out of reach...if they are falling out then fair comment if they fit well then code 3...quick fix... just spot some super glue on the plastic blanks, they can be cut out later if required. As for amd3 there is nothing wrong with using plastic blanks next to plastic MCBs under a metal lid.The company I work for periodically gets its EICR'S audited, one thing they pulled us for was plastic blanks in pre Amd3 boards 'easily removed without the use of a tool and readily accessible'
Any thoughts?
Reply to EICR audits _________ in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
