Discuss Electrak Busbar under floor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Customer has a set up using Electrak 63A under floor busbar, fed in 10mm armoured and backed up with a 63A c type mcb.
From this he has 32A unfused tap offs wired in 4mm in flexi conduit going to 16A rcd which then feeds 3.15A desk top supplies.
Am I right in thinking the 4mm feed needs protecting ?
I've not used or come across Electrak before so it seems odd to me that you can have a 32A 4mm unprotected supply tapped in to a 63A main supply.
Reply to Electrak Busbar under floor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
We have a customer in a large office block with all power in the building fed from an Electrak plug in busbar system. Lots of desks, lots of...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
  • Locked
5K
Done this loads of times before, but this situation is quite unique so bare with me. I've been asked to cable up an out building at a country...
