Discuss electric doors only open 1 way in the UK Electrical Forum area at ElectriciansForums.net
S
stodsy
hi iam a electrician and have come a cross a job thats new to me its on a set of doors that open as you come in front of the sencer but the problem is on the way in they do not open can any 1 who as work on these door help please and say what i should be looking for thanks alan
faulty sensor, broken connection, you need to open things up and have a look. try swapping the external and internal sensors, see it the fault goes to the inside.
so if i strip down the sencer that works and look at how it is connected up then check the faulty 1 to see any cable damage if not sencer is broken how much are these sencers and thanks
Is there not a selector switch on the doors somewhere??
Sometimes it's a simple rocker switch on the door unit itself, sometimes a stand alone key switch located above or to the side of the door etc.
hi lenny its all new to me sorry pal so if i go to the swicth am i looking for a break in the cable or a faulty swicth getting out of the block is fine but getting in you have got to pull it with your hands thanks alan
you need to find out the make and model of the door motor,most of these have a built in control board,it could be the pir/the motor/the board, anything could be at fault
Reply to electric doors only open 1 way in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Just a quick one if I may. I am currently about to fit 3 gang smart touch switch at my front door but owing to powering two sets of...
Hello All, I am in the process of trying to open a new Electrical Wholesalers in Wales / Western England. I have identified...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hi, I am not an electrician and looking for some electrical advice. We have had a new electric roller door installed at our warehouse. The door...
