robert 1950
Installation of a cooker in a renovated property, electric oven and a separate induction hob. The hob was to be gas - now with the induction hob, can it be fed from the oven radial via a dual wall outlet? The radial from the Consumer unit is 10mm T + E. The local isolation requirement can be met by the 45a switch cutting off oven and hob together. Switch, outlet and oven/ hob are within a metre or so of each other. Advice please guys.
