Discuss Electric screwdriver for 2nd fixing? in the Electrical Tools and Products area at ElectriciansForums.net
Is one better than another? All you need is forward and reverse, with the option of being able to select a suitable blade.
I bought one similar to this as it was about £16 and took standard 1/4" blades
I can't tell you much about it, other than it works, as I've never once thought of getting it when second fixing and instead simply use the terminal driver that's already in my hand.
I have the same one as @nicebutdim. It mainly comes out to play for fault finding, e.g. the other day I had a high r2 end-to-end and having narrowed it down to 5 or 6 sockets it does make it less tedious to quickly pull all the fronts off.
It's best feature is actually that it's not very strong and will stall rather than damage something.
That was my intention, but I never have it to hand and never think about it.
Must put it in the toolbox and make a conscious effort to use it.
Just got a Bosch Go a couple of weeks ago as i spied it at a bargain price in Costco. It's a replacement for my 30 year old B&D and is basically the same thing. Great for socket fronts if doing a lot of them, and a handy tool to have, but I'm still one for a manual screwdriver for most stuff like that. Impact drivers have no place on electrical work except fixing backboxes to the wall, and even then I think they're overkill, but they are brilliant for other construction work obviously, and I do like using mine for that.
I've personally never used one but seen bosch go is currently 35 quid in b and q. It says bare but I always thought a rechargable battery comes in it rather than a removable battery like a drill.
£35 isn't an unreasonable amount of money, but I can't fathom what goes through people's minds when paying £200 for a cordless screwdriver.
In other news; I used my cheap cordless screwdriver for the first time today. Wasn't ideal for the job in hand, and I'd killed the battery by tea time, but could see how it could indeed be useful. Just need to keep it in the toolbox and make a point of using it, but I wouldn't be upset at not having one.
Is the speed fast enough at 260 ? The Bosch Go is 360 rpm
Reply to Electric screwdriver for 2nd fixing? in the Electrical Tools and Products area at ElectriciansForums.net
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Experienced Electrician, C&G 236 Parts 1 & 2, AM 1 & 2 18th Edition Am 2. (JIB Gold Card) I've been out of the trade for some time, but did a...
