Snowy, so tell me why that cannot be a reasonable explanation.
Technically that could be the cause.
You'll have to ask Rockinit why he thinks it's a "Clowning around " statement.
My comment on getting a shock on an RCD circuit means don't rule out the source of the shock coming from an RCD circuit after you had put;
"it rules out the theory that there is an electrical circuit problem".
If someone reports / comments they've had a shock it needs immediate investigation.
and yet you stand at the kitchen sink, washing dishes, getting shocks, whilst 'er indoors is tucked up on the sofa with a G&T, engrossed in constipation street. what is the world coming to?
I blame all this equality nonsense that schools are shoving into kids' heads nowadays.
In the last 6 weeks I have noticed loads of static about. When getting out of a car, touching lift buttons, people, and it can be quite painfull and definately a shock. I would never rule out there is a real fault present but I would more often suggest to the client its probably static.
I've never found any conclusive answers but in some summers there are periods when I get loads of static, then one day it stops. (still wearing the same clothes, shoes, I thinks its something to do with the atmosphere?????)
Because irrespective of the electrical truth of the matter, it implied that electricity will 'only hurt you a bit' and that an RCD will save your life. Neither of these is necessarily true and a dangerous thing to state on an open forum where DIY Dave knows no better.
Or the guy on the other thread that said if he did touch 110v it would only give him a 'tingle' !!
No mate.............the current will give you the tingle and 110v can provide that 'death tingle' believe me.
I was taught/trained that in certain circumstances 'ANY' electric shock could kill .................a 'tingle' to one person is maybe a milliamp short of killing someone else !
I was told in no uncertain terms...........if I or anyone else received an electric shock and were still alive ........they were lucky.
I cringe at these 'so called electricians' who touch something after someone else has said they got a shock off it?
Domestic 240v and you touch it to see if you get a shock?
Do me a favour lol
Where do they get trained nowadays ffs?
give the missus some rubber soled `washin up` boots to wear togehter with the marigolds....
there problem solved...
A colleague of mine has mentioned that they have experienced electric shock symptoms whilst washing up. They say that all the circuits in the kitchen are protected by RCD so assuming they are working ok, it rules out the theory that there is an electrical circuit problem.
Possible earthing problem?? Can anyone provide any information what may be causing it and how it could be fixed. Many thanks
Check the sinks potential voltage between taps/pipes and sink, if greater than 50volts cross bond taps pipework and sink.
