Hi, my neighbour has had to change his electric shower (6kw) pull switch (32A) 3 times in 4yrs. Apart from it possibly being poor quality switches he,s replacing, I was wondering if there is any reason not to leave the pull switch isolator in the "on" position. Thanks
Not doubting your sincerity Clem, but how do you know that? if there is a duff connection then contact burnout will occur. Bite the bullet and fit a decent wall isolator
Just can,t quite work out Pete, how a duff connection can cause switch contacts to burn out. Surely a bad cable connection would not contribute to excess current going through the switch contacts ? But totally agree a wall mounted isolator is much better than a fiddly pull switch.
You said you had replaced it 3 times in 4 years??
Inside shower; faulty components, low ir, reverse polarity could all affect the isolator
Don,t want to go on and on Charlie about this stupid switch but can,t quite work out/get to grips with how these things would cause an increase in current through the switch contacts(only thing likely to burn out switch) but thanks all for input.
A maintenance spark not knowing what a bad connection can cause Gawd help us
Oh right? but it can cause arching, heat, high resistance joints, therefore burnt contacts, therefore failure, of circuit therefore failure of switch therefore non functioning equipment ergo shower.
Or do you agree with Charlie that things like reversed polarity, low IR, can cause an increase in fault current ?
Yes it can cause arcing,heat, high resistance joints all right but all this would be at the bad connection not through the switch contacts, where are you actually coming from ?
So there has been 4 isolators in 4 years..
Your connections in isolators have been ok..
You seem to be happy with the rating of the isolators..
So I would be now checking out the shower..
How do you know for certain they haven’t been switching it on/off under load?
I would test shower element and whatnot
Check out the shower for what ?
What are the causes of high resistance joints? burnt contacts or something else
Ayr
Electric shower pull switch isolator
clematis432,
Des 56,
