Discuss Electric shower using trunking in the UK Electrical Forum area at ElectriciansForums.net
Hi, not done many showers 9.5kw shower, clipped direct, 10mm cable, 40amp MCB no issues the thing I wanted to ask was, there was existing feed too small so new cable all newish tiles so going to run some 25x16mm trunking now do many shower have any knockouts on top? Or will I have to make my own and seal up?
Many of them do have a top surface entry option.
You don't normally need to apply sealant as they are designed so that any water entering the top knockout will run out of the bottom and not flow in to any of the connections.
Some advise against sealing as it can trap any water that does get in and cause more harm than good.
Reply to Electric shower using trunking in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
