Discuss Electric towel radiators in the UK Electrical Forum area at ElectriciansForums.net
R
Richard
Simple question, do electric towel radiators tend to have thermostats built in?
Fitted one today for a mate (no instructions unfortuanatly), but there was nothing on it to suggest that it was thermostatically controlled. I assume there is, but just checking.
Not sure about the larger sizes, but some are very low wattage and designed to be either on or off. I'm assuming with this type, there will be safety cut-out but no thermostat.
I think most of them have an overheat stat,but run at a fixed temperature there would be no point in a normal stat as they dont produce enough heat to warm a room,just take the chill off.
had to put one in a bathroom in a carvan park office which was controlled by a boost switch, which was useless cause it took longer than an hour to heat up, but what one asks for , one shall get..... think was 150W element
This one had a 400w element and you couldn't hold it after half an hour, so i'm pretty confident it will have little trouble heating the room. thanks for the input :)
Probably does have a stat then. They usually stick out of the bottom, in-line with the mains cable, so easy to see.
Reply to Electric towel radiators in the UK Electrical Forum area at ElectriciansForums.net
Hello and good morning all. I am putting in a first fix on a small extension. It will have its own fuse board coming from the main house. I plan...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi, I'm looking for some advice please. I'm not an electrician but have employed a registered qualified one to do some work for me and want to...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
