Discuss Electrical wire for electric shower in the UK Electrical Forum area at ElectriciansForums.net
MalcolmS
Hi All,
I hope you are doing well.
I am asking about the electrical wire. I am in the process of working on the floor across the 1st floor and while the decking is exposed I want to run a wire for future power shower. What wire should I use?
Best regards
Cable would be about 8m in total
The power shower - standard 240V
The cable would run in the void under the floor
I have no idea about other things you mentioned
For all the cost difference now versus having to replace later, put in 10mm cable and have a decent amount of slack at each end.
Somewhere along its route you will need an isolation switch so the shower can be switched off for any maintenance or if faulty, etc. Traditionally that was an adequately rated roof-mounted pull switch (e.g. Crabtree 50A type) but you can have a more conventional switch elsewhere so long as it is suitable for the environment as well as adequately rated.
For now just get the cable in and let any future spark worry about that aspect, but if you are planning building/decorating work then sorting out an expected switch position, etc, early on can save a bit of hassle.
Awesome. Thank you. I get the wire sorted in advance.
Just be careful how you run the cable, make sure its routed sensibly with no strain and if run with other cables make sure there is plenty of room and no damaged is caused when pulling in. Avoiding routes where it could be damaged by nails/screws and is not draped over or too close to metal pipe work. It may also require additional support depending on the intended though in most underfloor circumstances there is usually little if any required. Also beware of guidelines regarding drilling through floor joists.
There is guidance available on installation methods and cable routes. My advice would be to look this up before you plan your route.
Post #10 is great advice. You don't want to end up getting an electrician in to fit the shower in the future and him refusing to install it/sign it off because the cable routing doesn't meet regs.
Reply to Electrical wire for electric shower in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hi all, The PRD went on my Triton electric shower. I opened it up to find out where a replacement would go, and someone mentioned that the wiring...
