Discuss Electrical Zones in the Commercial Electrical Advice area at ElectriciansForums.net
Elec96
Hi, I am in a debate with a friend who is also an electrician who is backed by his boss in this. Now I am aware of all the electrical zones like - 150mm from a ceiling and 150mm from the corner of 2 adjoining walls or partitions and horizontal or vertical from any accessory or switch gear. But the thing I don't agree with and can't seem to find any information about is that from a metal back box in a wall there is a 50mm zone all the round it? Ie. If you had two boxes in line with each other you could run the cable round the edge of the 2nd box to pass it rather than go behind it. Is this true? Thanks.
No that's incorrect and can easily be proved by reading the regs or looking at the diagram in the OSG.
I’m thinking you can. The OP might be wiring a RFC, and may be looping ends rather than daisy chain, if you get my drift. So as not to over clutter back box with additional cable, that one could pass over or underneath. It which case, this cable would be in the zone above or below this accessory. Done this in stud work or dry lined walls. Tin hat on :)
Reply to Electrical Zones in the Commercial Electrical Advice area at ElectriciansForums.net
Rewiring an old farm cottage… every wall brick and previous wiring not done well at all. I can’t locate any of the prescribed zones diagrams on...
Hi, With respect to the cooker switch only. If I moved it 400mm to the left by extending the T&E from its original position using crimps, then...
I've been told I need to upgrade the main earth bonding to 16mm. The consumer unit is on the wall adjacent to the externally mounted incoming...
4K
Hi, I am involved in a local charity which is fundraising to restore a local pub into a community hub (and also a pub). The pub which is The Hop...
