Search the forum,
Discuss Emergency lighting help in the UK Electrical Forum area at ElectriciansForums.net
Depending on where the board is they may illuminate for a short period then have failed by the time he gets there. He may only be flicking the test facility quickly but need more info and he seems to have gone.
Nope, i can see the lights from the consumer unit and watch the lights when i switch them off.
Hmm. If the green LEDS stay on when the test switch is operated, the wiring is wrong as per Davesparks' suggestion but the fact the LED is on should indicate reliably that the battery is on charge, not merely that the PL is live. So although the test switch would not test the fitting in the intended manner, if the battery is good then the fitting should still function during power loss. If the green LEDs go off when the test switch is operated, then there's no evidence of a wiring error and again the fitting should still work.
I think we've gone as far as we can go with the evidence available and investigation with test equipment is now needed to make any useful progres...
Which could just be the lamp obscuring the LED
The green led is illuminated and goes off when flick tested and mcb switched off.
So test facility operates them all but the mcb does not even though all the charge leds extinguish when the mcb is off.
Yes thanks everyone, our contractors are coming in Monday to take a look as they have done some work on the lights. I thought i would put it out there just in case there was an easy fix without me calling them.
Interesting post. As previously commented on by others. I'd be looking into the key switch possibly switching incorrectly perhaps the switch feed, strange that although the battery is charged it does not illuminate when power is cut.
I've previously seen like for like lamp changes cause electronic ballasts to become faulty on em lighting. They can be high maintenance sensitive bits of kit
Reply to Emergency lighting help in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
Hi all Got a question regarding HMO compliance. Visited property today for landlord looking to apply for an HMO license for one of their...
Afternoon all... The customer has a number of small green lights in the ceiling that are always on. This is a bed and breakfast/hotel. I had...
5K
Hi So I'd like a maintained emergency light but without the automatic emergency function to trigger in the event of power failure. In other words...
