Discuss Emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
just treat it as a normal switch, all it does is break the mains to it when you operate the test switch
if its maintained the e/l will have a sw/live connection which is where you would wire in with all other lighting, so the emergency light is lit up when a sw live is inputted to the uinit.
if its non maintained the light is not required to be illuminated unless the power fails to it.
eg.
6 amp mcb -----twin n earth------e/l test switch------main in to common, sw to e/l
operate switch it cuts power to fitting, reinatate and tube goes out (if non maintained) and charge light comes back on.
just treat it as a special light fitting with its own special switch, some peope designate them there own mcb and some people use the same power source that the ither lighting is on with.
Thanks for the reply when you look at it as a normal switch makes it alot easier to understand. Had a go at them today and understood it all, but still got 21 more staircases to go so should be a doddle by the end
cheers
Reply to Emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hello Got a customer who needs certification for a monthly emergency lighting test. What would be the best cert to provide them with? The NICEIC...
I tested a self test emergency lighting with three gears .While testing 2 of the gear doesn't passed 3 hour test but 1 Did Wit the same battery ?Why?
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
