Discuss Endoscope recommendations in the UK Electrical Forum area at ElectriciansForums.net
Bought this last month for checking where my cables were after cutting my holes for spotlights
Has an LED light on the end and is IP Rated for other applications.
It’s called a Crazy Fire Inspection camera on amazon for around £55 quid
Reply to Endoscope recommendations in the UK Electrical Forum area at ElectriciansForums.net
Basically as title, but can anyone recommend a good one. So far not seen a good one that I like, fitted a few for customers where you have to...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Evening all, I've had a few discussions recently that have made me realise that I know nothing about lighting. Does anyone have any recommended...
hi. would appreciate advice from any electricians. am trying to replace a 13amp [35 year old MK] wall socket but the terminal cage in all the...
