A property I am working in suffers from regular power cuts and energy spikes.
The property is the last on an overland supply, ( up on the hills).
I suspect that this supply problem is the cause of certain electronically controlled items being damaged beyond repair.
Is there something that could be installed in the property by an Electrician to help prevent this repetitive failure or is it something that is the responsibility of the supply company / DNO?
Are they supposed to supply a consistent Voltage or is being at the end of the line just tough luck?
How do they view it and what are their responsibilities?
