J
Jel
The lamps keeps exploding around a tenants house. We have tried different batches of lamps, a LED lamp even went black we fitted.
Any ideas why this could be happening?
What type of lamps (Gu10, MR16, E27) Also what make of lamps? Does the customer have a 3-phase supply? How long do the lamps last before they fail?
Yep I get a lot of this like tenant leave the track with 4 GU10 spots until the last lamp blows then they report there must be a problem as all the lamps went within a week and tripped the CB as well. I explain it like this the manufacturers tolerance on the lamps are tight so if the box says 2000 hours then you will get that so put 4 lamps in that all get the same run time then is it any wonder they all go in the first week plus GU10 tend to induce a high current when they go hence tripping the CB.
As for cheap lamps I always ask where did you get them corner shop or big shed and the majority say corner shop
Another consideration is the voltage rating. Most lamps are now manufactured to EU nominal voltages of around 220V. If imported from, lets say, China then you might have a problem.
Increasing the voltage by about 10% will reduce the lamp's life.
When we used to install tungsten photo lamps they were rated at 200V to run on a Uo of 240V. The lamps expected life decreased from 100 hours to 10 hours.
