LHensh
I'm needing to extend the cables I have coming from my garage fuse board as I am wanting to move the position of the first switch and socket in the circuit.
Would extending via Wago 222 connectors housed in a Wago junction box so the job for both?
It would be a far more professional job if you were to replace the sections of cable in their entirety.
That would be the ideal, but that would require me to replace the cable that is currently connected to the fuse box, something I wasn't planning on touching. Unless people here tell me it's no more complicated than wiring into a fitting?
I'm comfortable changing things beyond the fuse box and then having someone out to test my work
In a garage where 99% of cables will be run surface clipped or in conduit it is possibly easier to pull out the short bits and replace with longer bits thus to avoid unnecessary jointing
But if the op is more comfortable cutting and joining , then a wago box screwed to to a joist is fine
Ok I’ve just read the op properly instead of skim reading. If it’s in a garage where cables are clipped direct/conduit then yea just replace the cable don’t even know why this is a question tbh 😂 unless you have a monstrous garage just replace the cable. If it was a more difficult situation and not easy to run new cable then joint box is not a problem.
The OP responded to this suggestion in post #5.
Your suggestion was that a DIY member, who made clear they wish to carry out this work themselves, should replace cables to their CU.
I would never suggest a diy member does anything with electrics. As you know from my previous years on here I am strictly against any unqualified/ incompetent person touching electrics to save themselves a few £££. My apologies I did not even look at his status. My final answer to the DIYer - GET AN ELECTRICIAN IN. 👍
It's a garage fuse box, so presumably not too complicated inside, and isolatable elsewhere, so I can't see why a competent DIYer shouldn't venture inside it and change cables like for like.
I have my doubts I don’t believe anyone without suitable training/experience should be touching any electrics I didn’t take note that the guy was DIY always get an electrician in.
LHensh
UK
Extending 1.5mm and 2.5mm cables
LHensh,
nicebutdim,
