Discuss External gas meter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Correct me if im wrong but im sure in the corgi regs it states that you are not ment to bond the gas inside the gas meter box. How many times have you seen inside the gas box and the gas engineer seals the hole that the gas pipe goes through then Mr electrical comes ago and drills a nice 16mm hole straight in the back of the box to get his 10mm earth cable stick it in the hole and not sealing it???
We have all done it???????????????????
Reply to External gas meter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, So my factory needs more power, currently 100A/3p (70KVA) => 400A/3p (200KVA) UKPN wont upgrade existing supply and are insisting on new...
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
Hi Guys Would I be correct in thinking an electric cable can be as close as 25mm to a gas meter ? (not that I'd ever be that close out of...
I was wondering if someone might be able to help either confirm or change my understanding on the use of S-Type RCDs. I believe that they can be...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
