Discuss External Power Issue in the UK Electrical Forum area at ElectriciansForums.net
dazza1972
Forgive me folks, I can see the majority on this site are relatively well versed in matters involving electricity. Not me, I'm a complete novice that can change a plug, wall switch or light fitting ... not much else.
My scenario is we have an external cable taking power from our house to an outside shed. Unfortunately, the cable is not long enough to run along all the walls to get to the shed, therefore the previous owner has it running from the house straight to the shed so the cable overhangs between the two buildings... not exactly H+S conscious.... I want to extend the cable so I can run it all around the walls to the shed, thus not having it hanging over anyone who walks past between the wall and the shed!! Plus it looks unsightly and a poor excuse for a washing line!!
What's the easiest way to do this.? Could I install a fuse box to the outside house wall half way along, join the existing wiring into that and then run new wiring from the fuse box along the walls to the shed?
What do I need to take into consideration in regards to installing a fusebox outside? Does it have to be a certain IP rated?
Any suggestions gratefully received.
Best advice (considering the admitteded lack of knowledge) is to contact 2-3 different electricians in your area who will discuss the works in question and advise further action + a price.
Takes the 3 different prices, take note of the two prices that are usualy pretty similar, IF (as is usual the case these days) the third price is alot cheaper than the other two throw it in the bin. Contact the electrician wish to do the job and alls good.
During all this remember the works will need a certificate so use a Part P electrician to notify the works.
In summary:- if you limit is wiring a plug or changeing a switchplate.....get an electrician in.
You may find, depending on the distances involved, that it's cheaper to run a new cable over the whole length than install a suitable junction box and shorter length of new cable.
If you get a professional in, he can make sure that the new cable is of the correct type and rating and that it is protected by a suitable fuse or circuit breaker and that all other safety aspects are addressed.
Sounds like a complete lash up and probably won't even be suitable for what you have now. As pointed out, get a couple of quotes. This isn't just about work for sparks, it's about complying with legal requirements and insurance purposes.
Edit: Post your location, you never know one of us may be near.
ah, but the powers that be aren't concerned about safety per se. more about revenue raising, just the same as speed cameras.
Bugger legal requirements and insurance it's about making sure someone doesn't get a shock or die ? all this arse covering gets me down..
J
So bugger any notifiable work, sort of agree due to part P being a bag of poo.
As for the insurance, purely hypothetical, but if the OP's house burns down due to an electrical fault not related to this circuit, pound to a pinch of poo his insurance will use a 'non-disclosure' clause to get out of paying any money and the OP ends up on the streets...
As for arse covering, no. Just making the OP aware there's more to the job than just lashing a cable up.
As Terry Pratchet likes to say, 'Bugrit'...
Reply to External Power Issue in the UK Electrical Forum area at ElectriciansForums.net
I've had a search, and found an old thread from 2016... but was wondering about modern views on this situation. I've come into possession of...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
I would like to run power to a shed that is 40m from my other shed which is powered by a 10mm cable from the house. I have access to a 100m roll...
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
