- Reaction score
- 4,385
Remove the pilot drill once you have about 25mm drilled into the wall to act as a guide.
Nor do I?
Six inch holes are fun.
Nor do I?
Discuss Extract fan recomendation in the UK Electrical Forum area at ElectriciansForums.net
Appropriate length of 3 X 2 and a large hammer will deal with these. Many have met their end this way by myself and my trusty 4lb lump.Joists in an old building probably have herringbone strutting between the joist.
May be alluding to drilling all around the outside of a large diameter hole instead of diamond drilling, there is no doubt that diamond drilling does cause a lot of dust, but you do get a neat hole that requires very little finishing, even through plaster, and outside just a neat hole to put the cowl in.I'll retype that
Also seen something about drilling pilot holes to reduce dust but didn't quite get that idea ?
Reply to Extract fan recomendation in the UK Electrical Forum area at ElectriciansForums.net
