Discuss Extractor Fan in Downstairs Loo in the UK Electrical Forum area at ElectriciansForums.net
Hi Folks,
I've been asked to install an extractor fan in a downstairs toilet .
One that sits in the glass of the window. (That part has been done already)
I'm going to look at the job tomorrow so I'm assuming the window is just the glass and doesn't actually open hence the need for the extractor fan?
Will this need an isolator switch outside the toilet, as if it were being installed in a bathroom? Or can it just have it's own pull chord inside?
Is there a MUST for these to be timed units or can it come on and off with the light switch?
Will it need to have a FCU?
Just need clarification on these points as all I can see in the regs in installations in special locations. Although there's a strong possibility that I'm looking in the wrong place!
As always, feedback and help is greatly appreciated.
Most regs regarding extraction fans apply directly to brand new builds. Been ages since I have browsed through all the building regs but I’m sure extraction is all included in there...
Just out of curiosity:
I'm presuming you replace the glass with wood or something, that the fan sits in??? Or do you cut a big hole in the glass??
Doesn't the cable going to these fans look rubbish, if it's on show?
Yes, the fans that fit in glass always look rubbish.
You actually fit it in the glass? Wasn't sure if the vibration of the fan would cause the glass to crack over time..
@Spoon I have no idea about the installation in to the glass, this has already been completed but yeah, j agree it looks horrible imo!
Not being a domestic guy I was just curious as to how they do it. Love to learn things new.
One thing to bear in mind is that the manufacturer's instructions may stipulate a 3A fuse in the feed.
Which can be ignored as manufacturers instructions are guidance only. The fan should have built in protection, any fuse is to protect the cable, not the fan. The cable fitted to comply with regs must be bigger than rated at 3a. Finally this stipulation cannot be followed in other countries where FCUs are not available nor compliant.
Thomas. Unless the room has a bath or a shower in it (has it?) then if is like any other room. There’s no requirements for a pull CORD.
You can use regular switches.
Actually, contrary to common belief, there is no need to use pull CORDs in bathrooms - providing they are not inside certain zones.
PS a CHORD is played on a piano. It cannot switch on a fan!
Reply to Extractor Fan in Downstairs Loo in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
