Discuss Extractor fan with no external vent in the UK Electrical Forum area at ElectriciansForums.net
Hi All
I need to install an extractor fan for a customer but can't Vent it outside due to it being a basement and a concrete reinforced floor.
This basement is a commercial building and getting very wet.
Ideally if I could find an extractor fan which changes the humidity to water so I can put it down the waste would be ideal!
We don't want to use a free standing dehumidifier but a small wall mounted one would be great which empties itself!
1st problem to overcome is, why is it damp and can the ingress of moisture be stopped, an extractor fan on it's won't do the trick, to lower the humidity the area needs to be air conditioned.
It's the main prep area and washing up area.
There's 1 walk in fridge and 1 walk in freezer down there as well.
There's also 1 toilet and general stores.
I need something which will solve the problem but cheap as well as this customer is on a budget same as all customers!
Trying to make a silk purse from a Sow's ear it won't work with an extractor fan on it's own, appreciate your problem, try explaining to your customer the basic science of air conditioning, a Chinese or Indian Restaurant is it?
Hi All
Couple of seconds on Google. Loads of them. Here's just one:
DCW10 Wall Mounted Dehumidifier
Same thing with a price:
Ecoair DCW10 10L Slim Wall Mountable Dehumidifier Splash Proof Remote Controlled DCW10 | Appliances Direct
Yes, but you aint getting rid of the problem are you?
Doesn't sound like water is coming into basement more it's the amount of people and work going on in the basement which would mean you have to stop people breathing and using water down in the basement,
Reply to Extractor fan with no external vent in the UK Electrical Forum area at ElectriciansForums.net
Evening all, Got a vent axia TX6 6” fan I need to replace. A like for like replacement is around £500, client is asking for a cheaper option...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Evening all, Installed many extractors, but this is a first for me. Customer wants the fan vented out through the soffit, with an inline extractor...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
