R
Rabbit
Hi all
Your thoughts on this please. I've been asked to change a ceiling mounted bathroom fan for an inline duct fan to be put in the loft. No need to alter existing wiring - 3 pole switch outside bathroom and manufacturer states that new fan doesn't have to be fused down to 3 amps. Existing 3 core to ceiling fan will connect to new fan without extending.
Would you do this as a like for like change or as it's a different type of fan would you notify it? Or as the new fan is going in the loft is it non-notifiable? I'm not Part P but work with someone who is so can do it as a notified job if needed.
BTW, fan I'm thinking of fitting is 4 inch S&P 250T through about 6m of duct. Anyone had any experience of them?
Cheers
as your fan and all wiring is in the loft, it's not in a special location so i would say not notifiable.
Thanks, I was thinking non-notifiable but then got talking to someone and started wondering about it. Thanks for your reply.
Find wiser things to spend your money on than unenforced, and on this occasion unnecessary costs, to a job you were trained to do before the silliness came to domestic works :)
You're not wrong Des. Irritates me that a simple job can get caught up in this stuff but that seems to be how it is at the moment. Cheers.
