V
Victor
Hi Guys
I had a call out by a local letting agent to look at a fan heater in a bathroom of a rented flat, when I got there I found that the fan heater is partly in the shower cubicle but the actual switched spur is fully in the cubicle. I have checked the CU and found that there is no RCD and the breakers are all rewireable fuses and the spur is part of the ring-main and bathroom if fully tiled so no way of accessing the wiring of the ring circuit.
I have quoted to do a board change and remove the fan heater and spur, I was thinking of isolating the cables to the spur/filling the back-box with gel and fitting a blanking plate, then installing a new spur and fan heater on the opposite wall.
Anyone got any other ideas as to resolve this problem
Many thanks in advance for any assistance given.
Regards
Victor
Regards
Victor
