Discuss Fan in Bathroom in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Darius-parky
Hi guys. A client wants me to fit a fan in her bathroom.
She wants it to be operated with bathroom light. So far so good. It is a low voltage fan, 1.5 mm feed connected to bathroom light SL going to transformer and from tranny to pull core switch into the fan. But she wants to be able to operate it without having the light on as well. For instance in a during the day when she doesn't need to switch the light on.
Would I be able to do that? Is this possible? Am I making sence or have I forgotten to take my brain out of the freezer. Any advise please?
tAKE THE FEED TO THE FAN VIA A DIFFERENT PULL SWITCH,IE,L&N FROM LIGHT TO PULL SWITCH TO TRANNY TO FAN,ALTERNATIVE AND BETTER WOULD BE TO USE A SWITCHED FUSE SPUR EXTERNAL TO THE BATHROOM.
HOPE THATS RIGHT
ATVBITWWW
Thanks Rum. The first method from light to pull switch to tranny to fan is absolutely fine. This way when she turns the bathroom light on she can operate the fan via pull switch. But she wants to be able to operate the fan without having to rely on the light being turned on as well.
I think I'll have to look for a two gang pull switch for her. One gang connected to the light SL and one gang having direct feed. In any case since there is only one trigger point on the fan she has to put up with the quick flash in the bathroom light wehn she tries to operate it independently as the light would be in parallel with the fan.
Does it make sence to you?
No You Didnt Read My Answer Right ,take L&n To Switch ,NOT The Switch Wire And Neutral .
You Will Nead A Different Switch For The Fan ,seperate From The Light
Good Luck:)
Darius,
The fan will trigger (as you put it) ,as soon as it gets some juice ,weather it gets it from a switchwire or a live,
if you want it to run perminent ,ie ,not on its timer you wlll need to bypass the timer in the fan if there isnt a terminal to enable perminent running,and feed it with a live,not a switchwire
also i dont get why the light would flash ,if you wire it in parrell with it ,why?
and do they do 2 gang pull swiches,ive never sean one,if you find one please let me know.
all the best with it
Reply to Fan in Bathroom in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
My extractor fan has given up the ghost this week and I was hoping to replace it myself, however I cannot do a like for like swap as the current...
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
