Had the same fault as above but on a smaller scale (only 30m-35m run).
BS88 L1 blowing taking out a third of a small office block. No obvious reason why until I looked at the newly laid cable run. It was across the entrance of a private car park and the entrance was being used for access to a new building site next door. An empty excavation truck went over the new tarmac and nothing happened. 5 minuets later a loaded truck drove over it and BANG!
Dug up the trench and they may have well used sharpen granite for back fill! It had a "dusting" of sand and the rest was just big chunks of rock. Narrow down your search, hire one of the testers above and check wherever a road goes over the cable run.
  • Agree
Reactions: ruston
Averaging 18inches
Any sand bed under and over the cable, or cable tiles covering the cable, or has it just been chucked in Willy Nilly and back filled with whatever spoil was left from digging the trench?
  • Agree
Reactions: 1 person
I know sand bed under and over of 100mm I was there for that, as I know they wouldn't if I didn't make that clear. Back filled with excavated spoil, I understand
As already mentioned then possible high traffic area might be the site of the fault, you could hire those testers I posted info on, but it's a specialist operation, best bet maybe would be to get a cable tracing company in, the one I used way back was THOMAS CLARKE, don't know if they are still in existence, but a quick google search would come up with option. Good Luck.
Reactions: ruston
If you can access it you can trace it. However if there are areas that are difficult to access, but you know the route accurately, you could TDR it to find out how far away the fault is from 0ne end. With a reasonable fix from that, a likely cause such as recent groundworks may present itself near the expected fault position.
Sorry whats TDR?
Reactions: kibble19
So not sure or guaranteed, what was the spec for the job to be done as if someone has screwed up then its their problem and cost to rectify and to reimburse you for your time and expenses.
  • Agree
Reactions: ruston
Whetstone bridge theory and performing a Murray loop test if you have a couple of good cores or core and armour.
120mm direct in ground seems a bit small for 300amps let alone the 530M run?
Rough calc volt drop would be about 20v for 120mm For that length at 300amp using x value
Fault on underground Sub Mains cable
kibble19,
telectrix,
