Guest viewing limit reached
E
eddyg2007
I was working in a pub where the bar lights were not working........ the circuit breaker was tripped so i turned it back on and i was getting power to the other lights as they were working but the lights above the bar were still off, so i went up to the ceiling to look further into this fault. I managed to trace the cable to where it was coming from which was up through a joist. I am not getting power to the transformers as it is 12v downlighters. any1 any ideas as where to go from here? thanks
if theres no power to and not from the transformer then the problem lies either from the last light working or from the last light to the j/b-j/b to transformer
Fault with bar lights?
Talk Electrician Forum
eddyg2007,
sparky1ste,
