Discuss faulty Crabtree MCB in the UK Electrical Forum area at ElectriciansForums.net
H
Hawk
Anyone ever came across one of these MCB's not resetting?
Polestar?
Had loads of mcb's of all makes over the years which wont reset due to the internal mechanism being kaput....often seems to be on older breakers which have tripped on a fault.
Yeah polestar. I tested the circuit and found no faults! Connected into another lighting circuit, temporarily and it works fine. I will get a replacement tomorrow hopefully. Would CEF stock them?
I suppose they will order one in for you very much doubt they will have them in stock and your looking at about £1,000000 give or take a pound or two with CEF! I would ring around or have a look on line with fleeeeeebay etc !
Reply to faulty Crabtree MCB in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I needed to replace an MCB for an electric shower with a different rating, it's an older Loadstar consumer unit, and crabtree told me word...
Hi All, I understand the requirement for PEN fault detection on EV chargers for TN-C-S installs (or to place an earth rod). However, when I was...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
