Discuss Faulty Electric Meter - HELP! in the The Welcome Forum area at ElectriciansForums.net
MDL83
Hi all,
Having a bit of a nightmare with my electric meter in my currently empty property. Despite no electricity being used in the property the meter has been constantly moving forward at more and more of an increased rate as the weeks go by and nights draw in. Nearly 100 units were used in last 7 days! I'm currently only using about half of that in the property I'm currently living in!
Any ideas why it would be doing this? I've ruled out that the meters have been wired up incorrectly to my neighbours - theres is a pre-payment meter. There's no outside socket which somebody could tap into and no outside security light.
I've raised the issue with Scottish Power and having got nowhere have now escalated to the Energy Ombudsman.
Has anyone experienced similar issues?
Hi all,
Hum ..... switch off Fuseboard ..... then go round inspecting all sockets, switches and lights on or near the dividing wall with next door.... and in the loft .....
Either someone is stealing and using your electricity ?
Or your electrical instalation has a leak to ground ?
Both require the services of an experienced electrician
Call one
In the mean time turn off the main switch
And lock it out if need be.
Leak to ground using 100 units a week are you having a laugh??
Reply to Faulty Electric Meter - HELP! in the The Welcome Forum area at ElectriciansForums.net
Hi all, So my factory needs more power, currently 100A/3p (70KVA) => 400A/3p (200KVA) UKPN wont upgrade existing supply and are insisting on new...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
I've been a member for ages but received an email saying I needed to post on the Forum or my account would be terminated, so here we are. My main...
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
