This is what it looks like at the moment. I don't have spare wire so won't be attempting any more tonight. Probably a stupid question but are there different types of wire I need to conscious of?
Also, as mentioned there is no isolator switch for this fan so I'm assuming it is just linked to the lights witch if it works at all. Is this safe? Thanks again everyone.
sleeve that earth wire and put in a block connector. then link L to S/L (terminals 1 and 3) with a bit of 1.0mm wire. cut those existing cable ends back a bit so that when fitted, there's no copper showing.
Just snip a little more off the bare ends and put back in terminals so theres not so much bare copper on show, you need 1.0mm cable, could give that one a gentle tug to see if you can gain a few inches on it to snip a bit of brown off, needs a slight tidy up anyway as the blue is nicked
as the blue is nicked.
wasn'tthis Scouser. honest.
You possibly need a link from the live to switch live terminals for it to work.
And there is too much copper showing on the L & N cables where they enter the terminals.
Thanks, yes we established
sleeve that earth wire and put in a block connector. then link L to S/L with a bit of 1.0mm wire. cut those existing cable ends back a bit so that when fitted, there's no copper showing.
Excellent thanks. Don't have either of those to hand so will do another try to do it by torchlight one evening this week. If not the weekend so don't assume the worst if you don't hear from me for a few days ?.
What do you think about isolator switch? Is it safer/better to have one in this case or do you think its OK as it is?
Thanks so much for your help
isolator switch would be trhere to isolate fan for maintenance and still have a working light. if you can see to work on the fan without the bathroom light on, there's no need.
Went to electrical store today and got some earth sleeving and they cut me a piece of wire to use. Fitted as per pic - the switch live is also going into the live terminal but slightly hidden by the live wire in the picture. Turned on light and... Still nothing...
Hmmmm, may now need an electrician with some test equipment to try and trace the cable and see if you've lost supply,neatly done tho
I'm well aware I'm useless at DIY, I'm trying my best to learn some practical life skills hence joining this forum. I really appreciate your help and time!
This is admirable and I agree learning some practical skills a great thing to do.
However electrical work is not the right thing to learn by having a go at it. Electricity can be very dangerous and it's not worth the risk.
OK, thanks for the advice everyone. May not have solved the issue but I've learnt a lot! Will call in a pro
