Discuss Faulty microwave combi- oven in the Electrical Appliances Forum area at ElectriciansForums.net
I have a fitted Zanussi microwave combi -oven which has stopped working. Door switches etc are OK as I have a 240 volt supply to the high voltage transformer, this transformer checks out OK. I did find the high voltage diode was faulty and changed this but oven still did not work. As I understand things if there is a 240 volt supply to the high voltage transformer then the fault must be with the transformer itself, the diode, capacitor or the magnatron. The transformer is OK, the diode checks out OK, have replaced capacitor with a known good one so this leaves the magnatron. There is a continuous very low reading between the two terminals and no leakage to earth and no visible signs of any damage, is there any other way of testing the magnatron or does anyone have any suggestions on what I may have missed.
I know it would probably be easier to buy a new micro wave oven but this unit matches up to the fitted oven and is no longer available. Thank you for reading this any help or advice will be gratefully received.
The unit is a Zanussi micro wave combi oven model:ZKC44500XA
I can't really help on this one, but be bloody careful around that high voltage capacitor.
There is one available (from my favourite source of otherwise unavailable things ?), but lots of £££ !
Edit: there is confusion in model numbers in the listing - might be worth checking out exactly what is for sale.
Reply to Faulty microwave combi- oven in the Electrical Appliances Forum area at ElectriciansForums.net
Hi All, Seeking some thoughts on my own Omega free standing 900mm oven. Over the past year the oven has been tripping the supplying RCBO unit. I...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
