Discuss Fike zone faults in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Have you programmed it using their software. What was the problem with the Twinflex panel you replaced.
Why haven't you connected the cpcs to the appropriate terminals.
Have you programmed it by way of the usb port.
[/QUOT
It is replacement penal I do not how to programme ,I tried to follow its manual. but I cant get it right.
[/QUOT
no I did not use software as I had couple of suggestion which recommended I do not need to use sofware
i have been suggested there is no need to use software.
Basically I do now how to program it.the old was faulty and it was showing EOL missing,I am not competent but I am an Elecrition trainee ,I thought there is no need to put cpcs in appropriate terminals as old one was in connector blocks so I did same.
Thanks again for your help
CPCs should always be correctly connected, just because someone previously didn't and created a dangerous situation it does not mean that you should copy them.
Reply to Fike zone faults in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, My alarm system is a Texecom control unit (Premier 64-w) + Keypad + Sounder, and is using the wired zones 1-4 only, with no additional...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
My FIL wants a cctv system at his house, and normally i would just go with whatever kit was on offer at the time from t'internet. My own system...
