Andy78
Mentor
I have a job to do that requires the removal of a dozen or so downlights in a plasterboard ceiling to make way for surface LED bulkhead fittings. I cannot overboard and skim as the room needs to be in use and the downtime needs to be as short as possible, plus there are existing ventilation ducts I would rather not beggar about with.
My usual method for this is to fill the hole with a circle of plasterboard held in place with a short wooden batten, and fill the gaps with fine filler. Tis a bit laborious though.
My question is does anyone know of a downlight filler plug to make my job easier and quicker. It feels to me like they should exist for these sort of applications, but I have searched high and low with no joy.
Cheers guys, looks like the standard method. Polo, that mesh stuff looks ok but looks like it would require a skimming which isn't possible in this case.
Just an idea, cut out some thin ply, just enough to fill most of the whole, insert fix either side with screws, then apply some bonding, then finish, but may take a bit longer.
I would get a load of short lengths of batten the same width as the hole, put some easi fill 20 min plaster on it at both ends, poke it up the hole, position it, give it 5 mins then wack a load of 20 min filler over the remaining gap.
Do as you suggested in your original post but cut your plaster board circular inserts in half, making two circles of half depth. This will then make inserts for two holes. Fix as you would do normally and then rough in with a little bonding. Half hour later skim to finish. Should finish up with a good smooth plastered ceiling. That is how i do it. Bonding attaching to side of original plaster board will alleviate any cracks at a later date.
Neat way to do it is fix a batten in place by using one that overlaps the gap by 50mm either side and screw through the ceiling into it, then fit a circle or square of new board into gap and skim over with easy-fill or easy-sand. Don't use skim as you won't get a good finish. Light sand when set and you won't notice the repair.
Done it many times. Once we had to drill twenty 6" holes in one ceiling on a student accommodation when revised kitchen drawings were issued. We drilled the holes, re-wired and put the cutouts back in but the dry liners did the final finish.
Cheers everyone. I'm fine with the patching method and that's what I'll be doing, just wondered if there was a "blank plate" solution out there.
Maybe a marketable idea if anyone fancies fixing a couple of downlight springs onto a plastic disc. Saying that, this is the first time I would have ever used them, and possibly the last .... lol
Andy78
Mentor
Kingston upon Hull
Filling downlight holes.
Andy78,
VoltzElectrical,
