Hello,
I have just had an engineer carry out some part replacements on my solar PV installation, and I’m seeking advice here because I’m concerned that my installation may present a fire risk.
What happened was that my system stopped generating in June. An engineer’s visit determined that the inverter was faulty, and that same engineer came back today to fit a new inverter. However, he soon realized that, even with the new inverter on, my system still wasn’t generating. He carried out further investigations by unscrewing the generation meter lid, and he found that the neutral cable inside was completely burnt.
He has now sorted the problem and my system is generating again, but my concern is about something he said. He told me that with the burnt cable, I had been lucky that my bungalow hadn’t caught fire. So, my thought at that point was, if the initial installation had been causing me a fire risk, could I still be at risk with the post-repair set-up that I now have? This engineer was from the same company that had installed my system about eight years ago, although he wasn’t one of the people who had installed it. He assured me that my system didn’t cause a fire risk any more because of the way that he had rewired it: he said he had made sure all the connections were very tight, and he had used an oversize cable… but I am still concerned about the potential risk. (He has also fitted a new meter.)
What are your thoughts?
it sounds like the original neutral connection was not tight... which caused the melting.
As long as its all new parts, and the cable is either cut back to clean copper, or replaced.. and the connection is tightened to the correct torque (too tight can be as bad as too loose) then there should be no further risk.
It did not overheat because there was too much load going through an undersized cable... it would be the connection not tight, and causing arcs.
That was the engineer’s first thought too.
How can I check whether everything has been fitted properly now? The old burnt cable was inside the old meter, which has been replaced. However, the cable has not been replaced. I know that because the engineer told me he didn’t have the correct cable with him – although I am not sure what he actually did.
So was the original inverter actually faulty?
According to the engineer, it was. I was sceptical about this too, in light of what happened after the new inverter was fitted, so I asked that very question to the engineer again and he confirmed that yes, the old inverter had been faulty. In all honesty, I am still sceptical about this, but as I am not a specialist, I could only take the engineer’s word.
I would ask for it back and get it checked maybe it was faulty maybe not.
The old inverter was your property,
Unless it was a free of charge replacement, and therefore a like for like swap, the old inverter is still your property.
I’m disappointed that they took it away/stole it from you.
I always ask people what they want to do with the old equipment that I am replacing, unless it is a unit that has failed under warranty.
The burnt out connection quite likely involved a fair bit of arcing at some point.
It is not 100% guaranteed to be the case, but equipment connected to circuits fed by arcing wiring - especially if the situation has been ongoing for some time - will often be damaged / fail as a result.
OK, thanks for all the replies.
I’ve got a further question now, because I have had some news from my electricity supplier regarding generation payments. I sent them a photo of my new meter, as they requested, and they said they couldn’t accept it because it showed a negative reading. They also said the problem may be due to the meter having been wired incorrectly, and this is what I would like some professional opinions about.
Now, I have been to check the meter again, and I have realized that it keeps displaying three figures in succession, as shown in the attached photos:
– a figure preceded with a minus sign;
– the same figure, or a very close one, without the minus sign;
– a very low figure, close to zero.
Then, it goes back to the first one and it shows the series of three in succession, again and again.
I have sent to my supplier/payer a photo of the meter showing the figure without the minus sign. This is the one from the second bullet point above, and it corresponds to the second attached photo. I hope it is going to be OK, but I haven’t heard from the supplier back yet.
So, what are peoples’ opinions? Do I have reason to be concerned about the potential wiring of the new meter? The main figure displayed has gradually moved from 0 to 105 between the day of installation and now, and the meter is showing a blinking red light, so my system appears to be generating electricity continuously as expected, and I am assuming that this figure shows the amount that has been generated. However, I can’t understand why it keeps appearing alternatively with a minus sign and without one.
Do I have any cause to be concerned? Is this meter behaving as it should?
The meter instructions can be found on the internet though it may not help! https://www.tradesparky.com/solarsp...-eca2nz-bi-directional-single-phase-mid-meter
The meter is set to continuously cycle between import, export and 'net' - being the difference between the two.
The red flashing light shows energy flowing, with each flash being one thousandths of a Kilowatt !
The arrows on each side of the screen tell you what the number is indicating.
So in your first photo it shows (from the RHS arrows) Net Kilowatt Hours are -104.8
Second photo (LHS arrow shows import), (RHS arrow shows kWh) and the result 105.0
Third photo (LHS arrow shows Export), (RHS arrow shows kWh) and the result 0.1 (should be 0.2 to make the sum correct but hey ho)
So the meter appears to show all (apart from 0.1kWh) of your electricity consumption is from the grid.
I think either your PV is still not producing anything (most likely), or they've wired the meter incorrectly (which is less likely, as I would expect you would have used more that 0.1kWh from the grid by now!)
Edit: I now understand the above is incorrect. This meter only shows PV generation, not taking account of supply consumption or feed in.
Thanks for all your explanations, but I’m getting confused now. According to other research I’ve done, my meter seems to show that my solar system is generating properly and almost all of the electricity generated is powering appliances in my home, with only a very small amount going to the grid.
What some Internet sources say is that this meter has been designed for installations with battery storage, but because my installation doesn’t have such storage, it can be wired in different ways and the readings would show different things depending on how it has been wired. That is probably the source of the confusion. In any case, my electricity provider — who are paying me for the electricity I’m generating – have accepted the positive figure (import) as showing the electricity being generated.
Well that is positive news!
I was surprised your electricity consumption from the grid is so low.
Is this Emlite meter just for PV generation, and you have a separate supply (smart) meter elsewhere?
