- Reaction score
- 0
Hi,
I'm drilling through the kitchen wall into the wooden leantoo. I'm using 20mm conduit through the hole, with a conduit box one side and a wiska box the other.
Do I have to use any fire sealing? Whether inside the conduit or around it as it exits the brickwork? I found a link that said you don't have to fire seal inside the 20mm conduit as it's too small, is that true? But I can't find anywhere that says about sealing the conduit exterior.
Many Thanks if you can help
