G
GNEL
Hello, i currently have a small project where i am required to fit a brake resistor to a vsd. i dnt no an awful lot on this subject. can anyone give me an explanation?
cheers
G
Hey mate.
I believe brake resistors are used to dissapate the heat generated in the DC links under" hard" or "fast" braking of the VSD controlled motor.
As for fitting one I wouldn't be able to explain it without actually viewing the setup myself.
Cheers.
Brake resistors are used to prevent the DC Bus voltage of the drive, exceeding a preset value during the ramp down or the decel period.
Brake resistors tend to be used when you have a fairly large load that requires a fairly fast deceleration rate, without this resistor the drive may trip on an overvoltage fault during decel, this could, dependent on the application cause a safety issue should this drive trip has you will lose control of the motor during ramp down, would like to know more about the application.
GNEL,
sparky123,
